Hello all,
I am trying to do work a around on the select multiple question. Since selecting multiple answers counts the combination of answers as one string; I wanted to see if I can use the relevant field or the calculate field to default to an answer only if a condition is met.
For example,
What is you favorite color?
1.blue
2.red
3.green
If blue and red were to be selected, then the default answer for the integer field would be "1" in both fields as well as both words "blue" and "green" would be placed in their respective fields. I will send a snapshot of what I am trying to accomplish. Any tips or advice would be great from you all.James Tedrick
Fernando
