Compare answers between two surveys?
130
01-16-2025 10:11 AM
RHammers
If I have two identical surveys that have all the same questions, is there a way for me to compare answers between those two surveys after they are submitted and display in a dashboard if they are the same or different?
I will be putting together a survey that is intended to be used as a teacher/student setup and need some kind of grading system in place, if possible. Any suggestions would be very appreciated!
Ed_
by MVP Regular Contributor
i think you already answered your question to use ArcGIS Dashboard to compare the answers.
Question | Analyze | Visualize
