I am unable to save collaboration setting in Survey123 Web. My survey uses a feature service and was created using Survey123 Connect. Otherwise works. Any ideas?
Hi Keith,
Are you going to share the survey with a group? If so, a while ago I had a similar issue. I suggest, in ArcGIS Online, put the feature layer and related files of the form into one specific folder then share the Survey with the group you choose.
Hope this works for you.
Cheers,
Wali
