Thanks for your reply James,
What do you mean by "This method would still require a task list somewhere that marks which hydrants require a follow up"?
This is the reason why I wanted something to retrieve the results from previous survey (like the "pulldata"). What I have in my initial survey is a "Select_One" field to select HydrantID. There's a "yes" or "no" question to know if hydrant was pumped. If answer is 'yes' then it has to be surveyed a second time. I createad a "Fall Survey (FollowUp)" and I was hoping to get the HydrantID that were pumped in previous inspection in some sort of "select_one" field. Of course, the Fall Survey (FollowUp) wouldn't start before the initial survey has been completed on all hydrants which gives me time to create a list but I'd like it to be as much automated as possible.
