Hi @BarbaraWebster1 , thank you so much for looking at my form!! I really appreciate it.
1. I was able to get this working. In my actual form I built this form based off of, I did have the query in there. It was still not pulling in the data, but I moved my relevancies from the relevant column into the body::esri:visible column and that solved the issue! What exactly changed with the relevancies with the 3.14 update? I haven't seen any documentation on that and it disrupted quite a few of our live surveys.
2. This fix did work for the integer values! However I have other forms with string values that this still is not working, I think it is related to the choice filter. We're experiencing a new issue where more than 2 choice filters on a field is causing it to clear out. I can send another example form with this & more detail.
3. Okay this makes sense, thank you for explaining that! We have that sort of if statement in all of out forms and we started putting a space instead of a null at the end. I will certainly test my survey when that is released.
Thanks again!
Adrianna
