Map tour zooming to incorrect points on mobile
171
01-30-2024 01:22 PM
Labels (2)
StewardshipAssistant
Having a strange issue with an embedded storymap on mobile. On the map tour, when you're scrolled halfway through a description box for a point, the map will zoom to the point 2 spaces previous. It will for instance zoom correctly to point 17 at first, then zoom to point 15 if you scroll a bit farther, then correct itself to 18 upon reaching the next box, before going back to 16 upon scrolling partway through.
This only happens on mobile on the embed in the web page, it doesn't happen on the previews. It's happened the same way on 3 different phones, and the behavior doesn't change if you use a mobile browser that requests the desktop version of the site. Is it possibly an embed error?
AbbyE_Esri
Hi @StewardshipAssistant ,
Would you be able to provide the link to the story that was seeing the issue in mobile, so we could take a look and see the behavior on our end? If not, a quick recording of the behavior could also help.
--Abby
