ArcGISRuntime 100.14 gpkx fails but the script runs fine with arcgispro-py3 from ArcGIS Pro
216
08-10-2022 08:20 PM
noodle
Because my gpkx fails under local GP service at arcpy.JSONToFeatures_conversion(), I tried with Visual Studio 2022 with Pyson Environment pointed to arcgispro-py3 under ArcGIS Pro 2.9.4.   The script ran fine with the same inputs.  I wanted to try the script with Visual Studio 2022 using Local Server arcgispro-py3.  It fails with permission denied.  Is there any way to do this?   I really want to debug to identify why Local GP server fails but runs fine under Visual Studio.  Interesting thing I found was that Local Server arcpy version is 10.9.1 vs. ArcGIS Pro 2.9.4 arcpy version is 2.9.4.  The version should be the same?
noodle
Here is the message from Local Server exception.  I'm passing in_json_file as string which contains the file path (the extension of the file is .json).   What does "Parameters are invalid" mean?
File "<string>", line 60,
in main File "C:\Program Files\ArcGIS SDKs\LocalServer100.14\64\Pro\Resources\ArcPy\arcpy\conversion.py", line 1169,
in JSONToFeatures raise e File "C:\Program Files\ArcGIS SDKs\LocalServer100.14\64\Pro\Resources\ArcPy\arcpy\conversion.py", line 1166,
in JSONToFeatures retval = convertArcObjectToPythonObject(gp.JSONToFeatures_conversion(*gp_fixargs((in_json_file, out_features, geometry_type), True)))
File "C:\Program Files\ArcGIS SDKs\LocalServer100.14\64\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512,
in <lambda> return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000814: Invalid file type Failed to execute (JSONToFeatures).
During handling of the above exception, another exception occurred:
Traceback (most recent call last): File "<string>", line 82,
in <module> File "<string>", line 63,
in main File "C:\AEDT\Temp\NETLOC~1\Documents\ArcGIS\Pkgs\jsonconversion_98A0\p20\jsonconversion\aedt.py", line 101,
in handleExceptions arcpy.AddError(e.message)
AttributeError: 'ExecuteError' object has no attribute 'message'
Message type esriJobMessageTypeInformative
