REST API Query Geojson Format Error
3073
5
04-02-2018 10:18 AM
MaryEllen_Perko
Occasional Contributor II
Hi.  I’m looking for some help with an error I get using the geojson query format when querying a particular map service layer hosted in AGS.  The error returned is “{"error":{"code":400,"message":"Failed to execute query.","details":[]}}” and seems to only occur on certain features.
If you are interested, you can see what I mean here:
https://gis11.services.ncdot.gov/arcgis/rest/services/NCDOT_STIP/MapServer/1/query
In the WHERE clause, you’ll get a returned feature if you enter OBJECTID=284.  If you enter OBJECTID=285, you’ll get the error.
Any ideas on what’s going on or where to look is much appreciated.
Thanks.
Tags (3)
MarieAlexander
Have you ever figured out the cause of this?  We are having the exact same problem!  Some polygons return the error, some don't...
BrianCollins
We have this problem as well. Our issue seems to be related to polygons with complex (multipart or donut) geometry. We get a successful response with all other formats but geoJSON throws an error. I'm going to open a support case on the issue.
MalcolmMeyer2
Did you ever solve this issue? I am getting rendering errors on complex polygons from a GeoJSON pulled from a feature service query. GeoJSON that is pulled from my open data site does not result in rendering errors. In the image below the brighter area is not there. I prefer the query method as it is slightly faster and it guarantees access to the latest data.
MarieAlexander
We ended up using a different format other than GeoJSON – I believe we just used JSON
LeithBritt1
I was just able to resolve the issue by tracing the bad feature, which was a polyline, attributing the new one and then deleting the old bad one.
