I am setting up the ribbon in ArcGIS Pro using a configuration. One of the buttons is a split button. There are currently 31 menu items plus separators. However, we'd like to move 11 of those to a submenu.
Is this possible? I haven't been able to figure out the right DAML and also have not found anything online on how to do this.
When defining a menu, you can add a submenu (referencing another menu). But menu is not a valid element under splitButton.
We cannot change the split button to a menu because we would like a default button behavior on it instead of just opening the menu.
TIA.
Kris
