Simple question, I hope:
What kind of "override" string expression is expected in this EditOperation.TransferAttributes overload method? Does anyone have an example or know of relevant documentation?
Solved! Go to Solution.
Hello,
Here is a sample of the expression that can be used to map field values between two features or rows with the EditOperation.TransferAttributes function.
return {
"ADDRESS" : $sourceFeature['ADDRESS'],
"IMAGE" : $sourceFeature['IMAGE'],
"PRECINCT" : $sourceFeature['PRECINCT'],
"WEBSITE" : $sourceFeature['WEBSITE'],
"ZIP" : $sourceFeature['ZIP']
Here's an example of a simple button that will transfer attributes from a source feature (oid 1) in the Police Stations layer to a destination feature (oid 2) in the same layer
protected override void OnClick()
var layer = MapView.Active.Map.GetLayersAsFlattenedList().FirstOrDefault(l => l.Name == "Police Stations");
if (layer == null)
return;
string expression = "return {\r\n " +
"\"ADDRESS\" : $sourceFeature['ADDRESS'],\r\n " +
"\"IMAGE\" : $sourceFeature['IMAGE'],\r\n + " +
"\"PRECINCT\" : $sourceFeature['PRECINCT'],\r\n " +
"\"WEBSITE\" : $sourceFeature['WEBSITE'],\r\n " +
"\"ZIP\" : $sourceFeature['ZIP']\r\n " +
QueuedTask.Run(() =>
var op = new EditOperation();
op.Name = "Transfer atts";
op.TransferAttributes(layer, 1, layer, 2, expression);
var success = op.Execute();
I'll make sure the documentation for the function is updated. Let me know if you have any additional questions.
Narelle
Hello,
return {
if (layer == null)
return;
Narelle
