How to show costum images in ArcGIS Pro notification?
1272
11-11-2018 01:46 AM
KarstenRank
Occasional Contributor III
I wrote an ArcGIS Pro addin with the SDK to show notifications.
Since Version 2.2 showing costum images in notifications should be possible. How can I reach them, if they are put to the image folder an should be shown in the internal class Module1.
notification = new NotificationItem(dateNews, false, thema, NotificationType.Custom, date: myDate,
 customImage: "pack://application:,,,/Module1;component/Images/globe30.png");
 NotificationManager.AddNotification(notification);
This toastimage is shown with this code:
 customImage: "pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/ToastLicensing16.png");
Thanks Karsten
UmaHarano
Hi Karsten
Is your assembly name "ProAppNews"? If so the the image url should be:
"pack://application:,,,/ProAppNews;component/Images/globe30.png"
If you right click your project node and select the Properties context menu choice, you can see the assembly name.
Thanks
Uma
UmaHarano
Hi Karsten
Thanks
Uma
KarstenRank
Thank you Uma!
It works again fine!
StefanDieters1
New Contributor III
The image must be a Resource rather than Add-In Content within your Visual Studio.
Set this under the image's properties.
