Is it possible to call geoprocessing from the ArcGIS Pro SDK and pre-fill the parameters?
Flow:
From a selected element on the map create a custom button where it will open the dockpane of the update subnetowrk geoprocessing for example, when it is opened it will already perform a pre-fill of the geoprocessing fields.
I know it's possible to create a button in the context menu, but I don't know if it's possible to open geoprocessing window via SDK and fill in the parameters.
Hi @jefferson_bzp, yes, you can pass parameters to any Geoprocessing tool and execute it from the Pro SDK. Please refer to the conceptual document, snippets, and advanced code samples.
Thanks for your help Aashia, I managed to find what I needed from the links you sent me. More specifically, that's what I needed:
https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Geoprocessing#open-the-tool-dialog-in-the-ge...
I appreciate it!
