Adding the "Locate" button to a custom toolbar
1019
02-26-2021 12:47 PM
BrianBulla
I add the Locate tool to my custom toolbar with the following code, but when it adds it, the pull down menu with "Seach", "Layer Search", and "Address Inspector" is missing.  How do I get that to show up too??
<insertButton refID="esri_mapping_showLocateDockPane"></insertButton>
KirkKuykendall1
Did you try esri_mapping_locateSplitButton ?
When I put this in my DAML:
I see this:
See idea posted here to make this easier:
https://community.esri.com/t5/arcgis-pro-ideas/show-daml-id-when-hover-over-downarrow-on-splitbutton...
KirkKuykendall1
I see this:
CharlesMacleod
This is what I see in the ADMapping.daml.
<splitButton id="esri_mapping_locateSplitButton" keytip="L" extendedCaption="Search for addresses">
          <button refID="esri_mapping_showLocateDockPane"/>
          <gallery refID="esri_mapping_locateGallery"/>
        </splitButton>
So, I think if u reference the locateSplitButton rather than the showLocateDockPane u will be good to go.
BrianBulla
Thanks guys.  _locateSplitButton worked.
