Summary Statistics outputs defaulting to Big Integer in ArcGIS Pro 3.4
129
01-16-2025 08:00 AM
Y_Samari
Since I updated to ArcGIS Pro 3.4.0, all the output columns from Summary Statistics tables are of the data type Big Integer, instead of Long, by default. This is causing a lot of headache as I previously had lots of models set up that did basic processing steps from Summary Statistics e.g. joining fields from summary tables to other tables and then running field calculator based on those fields, many of which are now not working because Big Integer is often incompatible with a tool or a step. I am having to rebuild with additional steps to create a new Long field in the summary table and populate that from the Big Integer field that is being created as output. Is this a bug? Would be great if it could be fixed if so!
