Are others having limitations using the split tool with irregular shaped parcels in a named version with branch versioned data?
My organization is transitioning from traditional versioning to branch versioning. We are utilizing ArcGIS Enterprise 11.1 and ArcGIS Pro 3.1.3 and 3.2. We are publishing parcel services from branch versioned datasets, and end users are creating named versions to isolate their edits until they see fit to rec and post. End users have been unhappy with the performance of the split tool in the branch versioned environment and provide multiple examples of the split tool failing or only partially working when a split is performed using a split line that spans several parcel boundaries.
Splitting parcels one by one works fine. However, when an irregular shaped line feature spans multiple parcels, sometimes overlapping a single boundary in several places, the tool does not fully split all intersecting boundaries, and the areas that do split result in stacked parcels because the original parcel polygon just stays rather than modifying or falling away.
During the use of the split tool, if one of the polygons included in the target list does not have the input split line intersecting it, the tool will fail with the following error:
Error: A polygon cut operation could not classify all parts of the polygon as left or right of the cutting line.
ESRI has communicated that bugs associated with this behavior have been logged (BUG-000150723 BUG-000151169) and fixed, but we have seen no improvement.
We had an architectural overhaul led by ESRI in anticipation of our adoption of web editing and branched versioning. Our entire system is updated, and we increased the recommended resources on all elements of our system.
