1. When I do Spatial join between two Polygon feature classes with below parameters, then i get 8 number of records as result:
Target Features - Polygon feature class-1
Join Features - Polygon feature class-2
Output feature class- .gdb path with file name
Join Operation - 'Join one to one'
Keep all target features - unchecked
Match Option - 'Are Identical to'
Search radius - blank
2. When I do Select By Location Operation with below parameters, then i get 10 number of records as result:
- Input Features - Polygon feature class-1
- Relationship - 'Are Identical to'
- selecting features - Polygon feature class-2
- Search radius - blank
- Selection Type - 'New Selection'
- Invert Spatial relationship - Unchecked
Ideally I should get same result, since Relationship I am using is 'Are Identical to'.
Please through some light here.
