I am trying to run a ArcGIS Pro Model from Model Builder that updates fields within an ArcGIS Feature Layer. i am would like this model to doing multiple field Calculation on a daily basis as the data is updated or added. The model works as long as I running the model in ArcGIS Pro but as soon as I try to call the toolbox through python and I get back
"ERROR 000732: Input Table: Dataset Permit_Status\Permit Status does not exist or is not supported
Failed to execute (PermitDuration)".
Here is the error I receive:
Python 3.4.3 (v3.4.3:9b73f1c3e601, Feb 24 2015, 22:44:40) [MSC v.1600 64 bit (AMD64)] on win32
Type "copyright", "credits" or "license()" for more information.
>>> ================================ RESTART ================================
File "C:\Python34\lib\idlelib\run.py", line 353, in runcode
exec(code, self.locals)
File "C:\Users\agcallis\Documents\ArcGIS\Projects\Permits_Duration\PermitDuration.py", line 3, in <module>
arcpy.PermitDuration.PermitDuration()
File "C:\Users\agcallis\Documents\ArcGIS\Projects\Permits_Duration\Permits_Duration.tbx", line 59, in PermitDuration
File "C:\Users\agcallis\Documents\ArcGIS\Projects\Permits_Duration\Permits_Duration.tbx", line 56, in PermitDuration
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 500, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
The value does not exist.
Failed to execute (PermitDuration).
During handling of the above exception, another exception occurred:
File "C:\Python34\lib\tokenize.py", line 374, in find_cookie
line_string = line.decode('utf-8')
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xd0 in position 0: invalid continuation byte
File "C:\Python34\lib\idlelib\run.py", line 126, in main
ret = method(*args, **kwargs)
File "C:\Python34\lib\idlelib\run.py", line 365, in runcode
print_exception()
File "C:\Python34\lib\idlelib\run.py", line 216, in print_exception
print_exc(typ, val, tb)
File "C:\Python34\lib\idlelib\run.py", line 206, in print_exc
tbe = traceback.extract_tb(tb)
File "C:\Python34\lib\traceback.py", line 106, in extract_tb
return list(_extract_tb_iter(tb, limit=limit))
File "C:\Python34\lib\traceback.py", line 65, in _extract_tb_or_stack_iter
line = linecache.getline(filename, lineno, f.f_globals)
File "C:\Python34\lib\linecache.py", line 15, in getline
lines = getlines(filename, module_globals)
File "C:\Python34\lib\linecache.py", line 41, in getlines
return updatecache(filename, module_globals)
File "C:\Python34\lib\linecache.py", line 126, in updatecache
with tokenize.open(fullname) as fp:
File "C:\Python34\lib\tokenize.py", line 439, in open
encoding, lines = detect_encoding(buffer.readline)
File "C:\Python34\lib\tokenize.py", line 415, in detect_encoding
encoding = find_cookie(first)
File "C:\Python34\lib\tokenize.py", line 379, in find_cookie
raise SyntaxError(msg)
SyntaxError: invalid or missing encoding declaration for 'C:\\Users\\agcallis\\Documents\\ArcGIS\\Projects\\Permits_Duration\\Permits_Duration.tbx'
File "C:\Python34\lib\idlelib\run.py", line 138, in main
print_exception()
File "C:\Python34\lib\idlelib\run.py", line 202, in print_exc
print_exc(type(context), context, context.__traceback__)
File "<string>", line 1, in <module>
File "C:\Python34\lib\idlelib\run.py", line 142, in main
traceback.print_exception(type, value, tb, file=sys.__stderr__)
File "C:\Python34\lib\traceback.py", line 169, in print_exception
for line in _format_exception_iter(etype, value, tb, limit, chain):
File "C:\Python34\lib\traceback.py", line 153, in _format_exception_iter
yield from _format_list_iter(_extract_tb_iter(tb, limit=limit))
File "C:\Python34\lib\traceback.py", line 18, in _format_list_iter
for filename, lineno, name, line in extracted_list:
Any help or suggest will be greatly appreciated. The main goal is to do daily field calculation on updated features inside an ArcGIS.com Feature layer using Task Scheduler.
