Required field doesn't work when I submit form.
348
05-23-2024 06:13 PM
FilipeJardimFernandes
Hello Team.
The problem is when I submit my form with all fields empty. on the fist time.
On Geohub, I create a new Form with my fields and I set some fields with required, but when I open the form to create a new layer then submit the form with all fields empty, it saved. Stranger if I edit, the form work.
Any help?
Also, here is the object that show the field is required.
stranger, if I click a field ans click another, it show the required message
Robert_LeClair
Esri Notable Contributor
This is the ArcGIS Pro Esri Community - I'd recommend you repost this question on the ArcGIS Hub Questions - Esri Community community instead to get a better response from the user community.
