I am looking to upload a feature layer from ArcGIS Pro to ArcGIS Online, as we have done hundreds of times before.
I keep getting this new staging error that I haven't seen before, I even exported my layer as a FGDB directly from ArcGIS Online, imported it to Pro, and immediately turned around to share it without making any edits - it's still giving the error.
I can still upload other layers with no problem, but this one is giving me issues for some reason. Any help would be great, thanks!
Update: I realized Pro was out of date on my device and that ended up fixing the issue, I have had problems similar to this before a while back with symbology.
It drove me in many different directions, I would repair geometry or change some settings and get a different error, but it all worked out in the end.
Shot in the dark, but are all the fields marked as visible when you’re publishing? I have seen a generic error when all fields are not visible but the layer has a setup that includes things like attribute rules.
We just had a similar problem, limited to certain computers in the office getting the Staging failed error. Could not publish under any circumstances where they had been able to publish recently. With the help of Esri support it turned out that those machines had an out of date version of XToolsPro installed. Without Xtools (or with the latest XTools) the problem was resolved. The incompatibility seemed coincident with a new release of AGOL.
