I experience a problem appending a feature class to a hosted feature layer. I use a model builder tool to execute an append on multiple feature layers. The model works for almost all layers, only one layer gives me a problem appending. I receive an WARNING 000595 and 000594 and no records from the offending feature class are appended to the hosted feature layer. There is an ESRI technical article from September 2022 that looks exactly like the problem I have.
https://support.esri.com/en/technical-article/000024458
Unfortunately, the recommended workaround did not help me. In the technical article, Esri acknowledges that this is "a known limitation" and refers us to BUG-000133544 for more information. But the hyperlink to the BUG article is a dead link.
I have tried to export the feature class to a new gdb, played around with every setting on the globalid field, tried changing the extent settings. Attempted to mirror all the settings of the feature classes that append successfully....Its extremely frustrating.
Any updates on how to fix this issue would be greatly appreciated. Thank You!
