Hi. I'm using the Create Locator 2.9 tool to build a Locator for matching street intersections. I would like the locator to prevent matching invalid intersection locations. For example, in the screenshot below it is an invalid street intersection address that I do not want the Locator to match. Lassen St & Lassen St should not match in this scenario. However, the locator matches to a location on a perpendicular street between the two parallel streets (Lassen Ct & Lassen St). Not only that, it gives it a pretty high score that would not make it possible to find in a large dataset through score alone.
I realize it would be possible in this scenario to flag this location before geocoding, but seems like this should be preventable (or at least scored significantly lower) when setting up the locator.
Is there a way to prevent this from matching or scoring lower that I am not aware of?
Thanks.
