Hi all,
I'm trying to convert a Mosaic dataset with several LUC rasters into a NetCDF file and always I've got an error.
I created a Raster Dataset with 10 rasters representing land use classes. Then I opened the footprint's table, and I added a field for the year.
When I run the Raster to NetCDF tool, it always ends up with an 999998 error. I tried using directly the raw Mosaic dataset, after building multidimensional info, using the year field for dimension time with type long or date.
I doesn't matter what I change, it always makes an error. Including, I restarted ArcGIS.
