Hello
I am converting images from 4-band 16-bit to 3-band 8-bit. Reason is to reduce size and since these are not for any scientific analysis, therefore 3 bands and 8-bit is enough.
I use 2 tools to achieve this. First "Make Raster Layer" to get 3 bands out of 4 and then "Copy Raster" to convert 16-bit to 8-bit. "Make Raster Layer" gives me a temporary layer which looks good, no missing pixels here.
After running the "Copy Raster" tool I get the 8 bit images and I see holes in them in dark shadow areas. I use below settings:
Rest all parameters are default. Its obvious that the lower values are being converted to zero as the data is rescaled from 16 to 8-bit. How can this be avoided so that there are no NoData pixels inside the image?
@VinayViswambharan can you help?
Sincerely
