Map Series: Possible to add table from path?
339
11-14-2023 02:26 AM
Labels (2)
NadjaHertel
Hi all,
I would like to create a spatial map series with dynamic tables in ArcGIS Pro version 3.0.5. Two of the tables contains data from feature layer, which is the easy part. However, I would like to add a third table with data from an external table. The table gets daily updated, so it is not possible to add the table as a standalone table to ArcGIS Pro because I need always the newest version. Is there a possiblity to add data in a table from a path? Probably with arcpy?
Thank you all,
Nadja
CarsonG
Depends on the file type of the external third table. If it is an excel table, it can be added directly into ArcPro for use. Or converted to an ArcPro table type daily for use.
