Lag in Copy and Pasting Text Elements in Layout Mode
142
11-13-2024 10:22 AM
ChinaLanger
When in layout mode and trying to copy and paste text/image elements in ArcGIS Pro 3.4, at certain times it is able to paste the element right away, but at other times it lags for a bit? Does anyone else also run into this problem? Closing out of Pro is my usual workaround.
VEAGISAdmin
I just started to experience this same issue in layouts within ArcGIS Pro 3.2. Even when attempting to copy/paste simple text elements, Pro will just freeze and after 15-20 seconds, it refreshes and the layout zooms out. Only then are the copied text elements selectable. Only solution so far is to close out of Pro.
