Im using a graphics layer to add annotations to site maps, when I try to print to a map from my map series some of the graphics disappear. For example:
I've tried doing just a polygon/shape graphic with a text graphic layered on top of it, and still have the same issues where some of the graphics print and some don't.
Anyone have any insight into this issue and how to go about fixing it/getting all annotations to print correctly?
Hi learnasyougo,
I'm not aware of any issue with map graphics being dropped in the print of export result for a map series.
The problem you are running into may be specific to your data/workflow. Can you contact Esri Support? They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Tom
