Thank you for the post! There are a few things that may change your analysis options:
- How many destination locations there are.
- If trucks spend a certain amount of time at each destination.
Given that, here are some ideas to start with:
1. To find the individual trips for each truck, we’ll use two tools:
- Split the tracks by “dwells”, which is when a truck doesn’t move very far over a certain amount of time. Assuming your GPS data files are points with date/time, location, truck id, and speed. Use Find Dwell Locations tool (https://pro.arcgis.com/en/pro-app/latest/tool-reference/big-data-analytics/find-dwell-locations.htm) to identify tracks. The input layer is the GPS point layer, and Track Fields is the truck ID. Distance Tolerance and Time Tolerance are determined by you. For example, if you think that a truck stays within 30 meters for 30 minutes between each trip, those are the parameters to use. You can start with a small dataset (e.g., one truck’s GPS records that cover a whole trip in one or two days), visualize the points, and get an idea how to define the distance and time tolerance. The output of this tool will create a point layer, with a new column to identify the GPS points that are “dwelling”.
b. Identify individual truck segments now that you know where they have “dwelled”. Use Detect Incidents and use an Arcade expression that will identify when a track has a different dwell ID than previously. To do this, the parameter track_fields should be the dwell id, and do a calculation like:
start_condition : var dwell = TrackFieldWindow("dwelled”, -1, 1); return dwell[0] != dwell[1]
end_condition : var dwell = TrackFieldWindow("dwelled”, 0, 2); return dwell[0] != dwell[1]
2. Then reconstruct the tracks for each trip, using the new ID column calculated in the Detect Incidents tool. This will help to visualize the travel path of the trucks. You’ll end up with some tracks of the “dwell locations”, you could optionally only analyze inputs where dwell id is null. This result will all show the duration of each trip. If you want to calculate wait times or where trucks are getting stuck (including or excluding the destination) run find dwell location and output the dwells as convex hulls. You will get polygons of locations, which you could analyze using a non-GeoAnalytics tool like hot spot analysis or count overlapping features (https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/count-overlapping-features.htm).
3. One solution for identify track destinations is by creating polygons or points for each known destination. Then, join each reconstruct track (line) to the point dataset to identify this location it intersects or is near to. You’ll use a spatial relationship as the join type (Intersect or Near).
Hope this helps! The workflow may change depending on the GeoAnalytics products (e.g., Server, Pro, or Engine) that you are using. Please feel free to reach out again if you have further questions with this issue or a certain product/tool.
