Extract values to points - 2 metres distance
369
02-29-2024 10:05 PM
Greta
Hi
I would like to extract raster values that are 2 metres away of the point (buffer 2 metres)
I did not find in the Extract Values to Point a parameter that has the option to add a radius
Are there any option available in ArcGIS Pro
Thanks
DanPatterson
MVP Esteemed Contributor
If you intend to use the data within the buffer radius for data analysis, perhaps you might want to skip the buffer step and just get the statistics from within the point and buffer radius
Point Statistics (Spatial Analyst)—ArcGIS Pro | Documentation
otherwise, you can use other extraction methods, like
extract by circle then raster to point
Extract by Circle (Spatial Analyst)—ArcGIS Pro | Documentation
Raster to Point (Conversion)—ArcGIS Pro | Documentation
The approach really depends on what you want to do with the data
... sort of retired...
