I've a map designed in ArcMap with all CMYK values correct, during export of the map to pdf ; 'Destination Colorspace' can easily be switched between RGB and CMYK. I want to open the same map document in ArcGIS Pro and export to pdf with same CMYK values maintained. I can't see 'destination colorspace' to choose CMYK option? Does Pro assume RGB only during export?
