I am consistently getting errors when I try to use the Manage Tile Cache tool to create a new tile cache. Using ArcGIS Pro v 3.1.
Error messages:
Start Time: Tuesday, September 12, 2023 3:53:05 PM
Generating tile cache using 16 parallel instances.
Generating tile cache for feature with OID: 1.
WARNING 001518: Failed to build tile cache for feature with OID = 1.
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
The index was either too large or too small.
ERROR 001517: Failed to generate tiles for SurfaceLayers.
Failed to execute (ManageTileCache).
Failed at Tuesday, September 12, 2023 3:56:23 PM (Elapsed Time: 3 minutes 17 seconds)
Thoughts? I am not doing anything crazy here, just trying to build a very simple cache. I have tried multiple cache locations on my computer either on the local C: drive or in synced OneDrive folders or in the same folder area as my geodatabase, etc., and nothing is working. I have reduced the number of scales to build based on my data and set parallel processing to 100%. Not sure what to do to get around these errors.
