I have searched in the blog a way to edit non spatial table (insert, update, delete) in web map or web app builder, but it apear that there is no way to do it (except for the related data to feature), it work only for feature layer.
so il have thinked of a way of accessing data outside the arcgis environement and i have used an ODBC connector to open the table in Access.
The table can be opened and edited, but the objectid, globalid and calculation with attributes rules don't work. when i add data i get this message "ODBC - failed to insert into table ..... error null value"
But when i set the value of the objectid manually it inserts the data and if we check on arcgis pro the data is in but it apear that the objectid or globalid didn'n work because the globalid value is {0000000}, and when i add new data in arcgis pro the objectid sequence may interfere with the value i set manually in Access
I think the field with calculation doesn't work ,
I am wondring if there is a way to solve this problème
