Create Fibre Utility Network model using PostGreSQL
483
07-18-2023 09:12 PM
Labels (3)
DeepikaJain01
Dear Community
I am trying to make a Utility Network Model for fibre Optics, I want to know if I can use PostGres as the enterprise database for the utility network. The ArcGIS Enterprise version is 10.8
Tags (4)
AnthonyRyanEQL
Postgresql is supported as a geodatabase but there could be issues with performance, etc. We have seen performance issues on SQL Server.
I believe another issue you will encounter is which version of Enterprise supports UN Telco. I'm pretty sure you'll need 10.9.1+
Good luck
AnthonyRyanEQL
Good luck
DeepikaJain01
Hi Anthony
yes we are fulfilling the requirements, the ArcGIS Enterprise version is 10.9.1. With the help of ST_Grometry I have transported the spatial data into PostGres. I need to check how to create UN Model in PostGres or can I migrate the existing sample UN Model from ArcGIS Solutions into PostGres.
