ArcGIS Pro (3.1.3) - Features to GPX
377
10-23-2023 02:20 PM
MichaelPillers
New Contributor II
I am attempting to generate some .gpx files (tracks) from some simple line features (with z values).  The process runs successfully.  The output files, however, contain three copies of each trackpoint.  This is causing a problem in the application that uses the .gpx files.
SeaRM
New Contributor III
Hello, Michael.
I can suggest you trying to use XTools Pro Export to GPX tool. You can export lines and polygons to GPX routes or tracks.
MichaelPillers
New Contributor II
Thanks.  I'm not using XTools so will continue to investigate cause, perhaps modifying tool coding.
