Arcade Expresssion
291
08-02-2024 12:45 PM
FranHarvey2
We have a field name:  valve service SDE.  The attributes are either "null" or a "url"  We have a working expression for the url to be returned.  We need an expression for when the attribute is "null"  return the text  "No Service Card"
CodyPatterson
MVP Regular Contributor
Hey @FranHarvey2
Here is a short arcade script that does just that if your feature is in this format:
var service = $feature.valve_service_SDE;
if (IsEmpty(service)) {
    return "No Service Card";
} else {
    return service;
Hope that helps!
Cody
jcarlson
There's also DefaultValue, which was made for this very thing. If there's a value, it returns, otherwise it falls back to the value you specify.
- Josh Carlson
Kendall County GIS
