3D points visible above 3D polygon even though elevations are below
277
03-06-2023 02:25 PM
NoahWasserman
I have 3D point layers and 3d polygon layers running elevation from their attribute tables.  The problem I'm having is seeing exactly where the polygons intersect the point cloud.  In the attached images the green polygon is the top layer, the gray polygon layer is the bottom layer and the points should fall between them.  If they poke out above, I need to know.  If I zoom out all of the points appear above the polygon layer (capture.jpg) and only if I zoom close and tilt to horizontal do the points drop down to where they should be (capture2.jpg).  I need to be able to adjust the polygon layer based on the vertical point cloud colors.  How can I ID the points above/at/below the polygon layers so I can adjust the polygon layer to fit vertically?
Tags (3)
