Please bring back the traverse interface that was used in Arcmap to Arc Pro. It was much more user friendly. One should be able to hit the "tab" button to enter in the next number in the adjoining field & also be able to import a sketch from your workspace instead of tracing (tracing is time consuming). Also, the traverse should be a continuous line & not in the form of line segments. To time consuming to select all the segments to merge them into one, before one is able to move/rotate the traverse. Lastly, when you complete the traverse, the red dot does not go away. The check mark and the "x" does not end the traverse, unless you select a different command from the ribbon.
