It would be really helpful for learning and efficiency if command tooltips all displayed the associated keyboard shortcut if one is available. There are a few that do this already (ex. undo), but it seems like most don't. Obviously there's a list of these online but having them right there would be really useful and save lots of time, not only in searching for the shortcut, but using it subsequently.
"Obviously there's a list of these online"
Just adding the link to the mentioned list here: ArcGIS Pro keyboard shortcuts—ArcGIS Pro | Documentation
@SimonSchütte_ct ope, yes perhaps not so obvious, thanks! I just anticipated someone linking it and marking the request as resolved...
@wayfaringrob have you tried in ArcGIS Pro 3.2 yet? Most commands with a shortcut assigned will display the shortcut in the screentip. If a command doesn't have a shortcut assigned, once you assign one, it will display in the screentip.
See this blog - I hope this helps!
@KoryKramer not yet. I might get it early next year. Thanks for the tip.
