Currently, when you're using the "Layer Search" feature of the Locate tool, it defaults to "Match Exact." I typically want to use the "Match any part" option because I am more likely to remember a fragment of a feature's name than the exact punctuation, capitalization, etc., but I often forget to change the default setting before searching and I get no results returned on my first try.
It would be great if you could change the default options in the preferences, or if Pro could remember your previous selection in the same local temp file that determines the layout of all of your windows/panes.
Locate Tool - Layer Search options
