Saved reusable text as insert option
389
06-15-2017 07:05 AM
Status: Open
ChrisMathers1
Occasional Contributor II
There should be the ability to add pre-made text to drop in, such as a disclaimer, that can be saved to the dynamic text insert menu. Layout insert can do this already with custom layout sizes, text should be able to as well for things that are regularly inserted.
4 Comments
JenniferBorlick
I would like to be able to save dynamic or static text that I have created to be able to re-use the text in multiple layouts.
TammiDoyle
Yes!
I regularly use a modified version of Spatial Reference dynamic text (the default is hardly practical) and it would be nice to have an option to save modified versions for quick insert.
AubriKinghorn
I'm not sure what you are asking for here, can you provide some more information? You can currently copy the text from one layout to another, as well as save and load queries and arcade expressions. What kind of interface would you like to see as a result of this idea?
TammiDoyle
I can only respond for my own personal needs, rather than the OP's needs, so hopefully they align.
I regularly add a 'company approved' version of dynamic text that is consistent across all of my figures.  One is Spatial Reference which uses part of the prebuilt Spatial Reference dynamic text and some additional static text. Another example is we have a particular preferred format for projected grid labels (e.g. xxx,xxx mE) that I copy and paste each time into the Map Grid Label Format dynamic text field. It would be nice if they could be saved as a 'style' under Dynamic Text in the ribbon.
Or is this already possible?
