Make PDF/JPG/PNG Exports Match the Map
175
03-07-2014 12:43 PM
Status: Already Offered
MikeNeal
New Contributor III
We should be able to export a map that matches the GUI display.  If you use scale dependent restrictions on layers you can not rely on this to happen, and have to manually check all output for all feature classes.  This was first reported as a bug in 2006, and is still not fixed.
http://support.esri.com/en/bugs/nimbus/TklNMDAyMzU4
"Exports of map elements with scale dependent visibility may differ at higher and lower DPI."
Tags (1)
1 Comment
AubriKinghorn
The Show preview option allows for this in ArcGIS Pro.
