ArcGIS Pro 2.6.8; Oracle 18c; 10.7.1 EGDB:
When using the Export XML Workspace Document tool, there isn't a way to use an SQL expression to filter the data:
I want to filter the data because I only want to export certain features to XML, not the entire FC. Details can be found here: Export XML workspace document — Only export certain rows
Could an SQL expression parameter be added to that tool?
Hello @Bud , have you tried this using Model Builder ? You can use a SQL Expression in the Select tool, and use that as a direct input to the Export XML Workspace Document tool.
@ChrisUnderwood That's a good workaround. Thanks!
With that said, I think it would also be useful to have it built into the GP tool.
