It would be helpful if all applicable geoprocessing tools allowed for:
I'm aware that we can work around tools where that functionality is missing, by creating a custom model and utilizing the Selection GP tool. However, I think that functionality should exist OOTB for all applicable tools.
In other words, I would like the ability to filter all GP tool input data parameters using SQL (using functionality right in the tool).
Related: SQL reference for query expressions used in ArcGIS
In ArcGIS Pro, the SQL expression dialog box can be found in the following locations:
- Select by attributes using the Select Layer By Attribute geoprocessing tool.
- Definition Query tab on the Layer Properties dialog box.
- Display filters tab in the Symbology pane.
- Create reports using the Create New Reports pane.
- Export tables using the Export Table geoprocessing tool.
- Export features using the Export Features geoprocessing tool.
- Use the Calculate Field geoprocessing tool to create an expression to perform simple or complex calculations on field values.
- Use Select to query data for further analysis.
- Use the Make Query Table geoprocessing tool to create a layer or table view.
- Use the Make Feature Layer geoprocessing tool to create a feature layer.
- Create a view in a database or geodatabase using the Create Database View geoprocessing tool.
- Use the Append geoprocessing tool to append multiple input datasets into a target dataset.
- Use ProSDK Core.Data.QueryDef.
