What happened to the security advisor?
353
11
03-27-2024 10:23 PM
yigalm
New Contributor III
I'm trying to use the Security Advisor at
https://s3.amazonaws.com/ago-security-advisor/index.html#
It looks like it has lost its connection to the CSS.
Everything is messed up and the tool can't be used.
Yigal
BernSzukalski
Esri Frequent Contributor
I like and use those tools and can see the same issues. I'll report that to the Trust.arcgis.com team to have a look at.
BernSzukalski
The issue has been reported and the security advisor developer will remedy.
EricO_Brien
Has this been resolved yet?
BernSzukalski
Yes, it has been resolved. The old Security Advisor has been replaced by the new one, so if you are using old links you might want to update.
Go to: https://trust.arcgis.com/en/
In the right corner click Launch Security Advisor
Then sign in from the upper right corner:
EricO_Brien
I just tried the link you kindly sent and I still get nothing from the web page. I can reaech it, and even log in, but when I try to run the analysis toll nothing happens. I tried a different browser and it didn't work that time either.
BernSzukalski
Let me check again. Which link are you using that seemed to fail?
EricO_Brien
Hi Bern, I used this link https://trust.arcgis.com/en/  that you previously sent.
BernSzukalski
I opened trust.esri.com and signed in to an ArcGIS Online account in Chrome, Firefox, Edge - all with no issues, all return security advisement about my organization correctly. As far as I can tell, everything is working as it should be.
EricO_Brien
I had one of our analysts try and he got the same response. Here's a clip of an error. Does it make sense to you?   Maybe a firewall issue on our end? Thanks again for your help.
Eric
