Warnings for JavaScript StyleSheet doesn't match Hub components in V 4.26
334
05-10-2023 09:23 AM
KT81
I have a Site Page that has started acting strange, We started republishing out map data using ArcGIS Pro this year which was a lot easier method, but at some point the links for the "You may be interested in" for the hub page at the bottom of the individual websites that is hosting data do not work.  I have used to the developer tools in the browser and found that the webpage is having issues with the getByCollection() method  is deprecated which seems to happen because the Javascript StyleSheet file doesn't match the hub-components verison of 4.26.  I was hoping someone could let me know if this is a issue with updates to the Hub or Portal for JavaScript, so I might tell our IT personnel.
Also I might add that the "You may be interested in" links are auto generated because I cannot find any place in or on the hub site editor that shows these links.  I have included the log file from the dev tools.
KT81
Any Clues or help would be appreciated.
