I'm using a print service to print a web map and I'm having trouble adjusting the draw order between layers. I have a point markup layer that I need to draw on top of all polygon layers, but no matter how I rearrange the layer order in the Web Map as JSON the polygon layer stays on top of the point layer. I also couldn't find any property like zorder that I could use. Is there a special trick to ordering layers in print services?
