How to change Hint Text for all searches?
283
08-08-2022 08:35 AM
Savannah2019
New Contributor III
Hi!
This is for a web scene I've made, but I imagine my question would apply also to a normal map.
I have a search bar in my web scene set up to search by specific layers. However, the "Hint Text" does not update to show my preferred text unless I limit the search to one layer. It still says the standard "Find address or place".  I have sadly accepted that I cannot disable the ArcGIS World Geocoding Service from my map, but is there at least a way to change the default Hint Text when searching all available sources?
Note: I know I can disable the geocoding service if I delete it from my organization. That is not an option as we use it in other maps. I also know there are apps that let you set your own search function, but with a web scene, those searches end up sending the viewer to outer space. I have to use the default search bar in the scene.
