Hosted View Table Query TimeStamp Issue
314
07-26-2022 10:51 AM
CESPEDESLUISITD
I am using a hosted view table that I need to create filters/queries for.
I tried using the Query widget but the problem is that when I do a date query, the attribute table loses the time stamp on the date field. The user needs the timestamp for exporting the result table.
There are no other widgets that I know that can query a table(view or not), all do only features.
Also, the result table for the query does not respect the table setting done on the pop up configuration. It displays all the fields for the table view. I dont want to show all fields on the result.
Now here is the kicker, if I open the attribute table directly from the table of contents and not with the widget, I can see the timestamp on the date, not only that, I see only the fields I configured on the popup. If I use the filter tool on the attribute table, it maintains the date with time and the correct table structure.
Why cant the widget do the same as the filter tool on the attribute table?
Am I doing something wrong or is this another limitation?
Thanks all
