Edit Multiple setting for Field Maps results in blank features in Map Viewer
517
10-17-2022 08:05 PM
Labels (2)
EmilyMcLean_onneer
When configuring a web map in Field Maps, if the Edit Multiple option is enabled, users are able to create multiple features one after the other in the Map Viewer or using the Edit Widget in Experience Builder. I was hoping this would be a way around not having access to a 'bulk editor' widget, like that in Web App Builder. But using this workaround instead results in all but the last polygon created having blank attributes (even for required fields). Is this something that can this be resolved so that when creating multiple features at once all resulting features have the same attributes?
Thanks!
Emily
