Hi @SeanCulpan
You need to use the view_layers parameter for the creat_view() method and supply a list of feature layers to add to the view, in this case there is one layer to add.
## create the view, the view will contain one layer
new_view = flc.manager.create_view(
name = "NAME_OF_NEW_VIEW",
## select the layer based on its id
view_layers = [flc.layers[6]]
Here's the full script that works for me.
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
## access agol
agol = GIS("home")
## access the feature service item that contains the layers
fs_item = agol.content.get("FS_ITEM_ID")
## create a FeatureLayerCololection object from the feature service item
flc = FeatureLayerCollection.fromitem(fs_item)
## get the feature that represents the polygon to apply as a geometry filter
aoi_record = agol.content.get("ANOTHER_FS_ITEM_ID").layers[0].query(where="COUNTY='GALWAY'")
## get the srs of the aoi
srs = aoi_record.spatial_reference
## get the geometry of the aoi polygon
view_geom = aoi_record.features[0].geometry.get('rings')
## access that layer
lyr = new_view.layers[0]
## create a dictionary to define the geometry filter with the aoi
update_dict = {
"viewLayerDefinition" : {
"filter" : {
"operator" : "esriSpatialRelContains",
"value" : {
"geometryType" : "esriGeometryPolygon",
"geometry" : {
"rings": view_geom,
"spatialReference":srs
## update the view to apply the geometry filter
print(lyr.manager.update_definition(update_dict))
I hope I got the workflow you were looking for correct.
~ learn.finaldraftmapping.com
