Changing the Field Order of a Feature Layer
1675
03-23-2023 11:54 AM
ThomasHamill
What's the most efficient way to change the field order of a feature service (or feature layer)?
Is it possible to do this in ArcGIS Online without having to republish a new instance of it with the revised ordering?
Without a straightforward way to reorder the fields directly within the feature layer's settings, the desired field order and pop-up appearance must be maintained in web maps which can become repetitive and time-consuming for feature services that are reused in multiple web maps.
Kindest Regards,
t
Katie_Clark
If you configure and save the pop-up/attribute field order through the Visualization tab of the feature layer's Item Details page, that setting will maintained for any map that layer is added to.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
BrandonA_CDPH
Is there a way to reorder the fields in the feature service itself? I export the table as an Excel for further processing. I recently had to add a field and it put it at the end, making the next step much mor difficult for the user.
Thanks.
AYamaguchi_UGRWCD
This is my same problem. It's frustrating but doable to configure the pop-ups, but my real issue will be in downloading the Excel file later for analysis. I don't want to have to download/reconfigure/reupload the layer because I already created the lengthy FieldMaps form associated with the original layer. @esriesri pls 😞
